It wouldn’t matter if we did know the manufacturer, after 20 years it’s typically not interchangeable.I appreciate that advice. I did look that up and indeed lever/ball is superior. However, I'm trying to
limp along with minimal changes as my field is very old and will need to be replaced eventually.
That's why I'm hoping someone here can recognize the valve manufacturer/model.
Why? It does not appear frequently used...the valve switches half of a gray water field on and off.
I thought stainless might be out of his price range for him to "limp along" as he wants to do. But Amazon is something else!A stainless ball valve with stainless handle would give better service. Pvc ballvalves have a tendency to get hard to turn then the handle breaks.
Why? <- i have a gray water septic field that has two halves. i manually go swap the fields about once a week.
Label <- ya, i went to my other existing valves looking for a readable label - they aren't unfortunately.
I guess I'm stuck replacing the valve.
Looks to me like it's been partially covered in dirt--anything that contains/retains minerals and moisture, and also exposed to air is a recipe for corrosion...For this service, I think I would still opt for the stainless steel rather than PVC, even if it not to ASTM standards. And as he apparently operates this weekly, I would assume he has a box with a lid over it for access to the valve.
Won't that block the flow? I'm assuming the leach fields are downhill from the septic tank, and bringing a section of the pipe up would create a reverse P-trap...Also, if possible, get it up out of the dirt with some 45° "ells"
Just 2 or 3 inches to get it out of the dirt--how much head is there? Creating a "reverse "P-trap" would require "reverse gravity"--and if you've figured out how to do that what are you doing hanging around here?Won't that block the flow? I'm assuming the leach fields are downhill from the septic tank, and bringing a section of the pipe up would create a reverse P-trap...
All 2" sewer lines should slope 1/4" per foot. Raising the line for the valve 2" would allow a buildup above the valve that would extend 8 feet. Raising it 3" would result in a backup 12 feet with 4 feet of that line being a pipe full of wastes. Gray water or not, leaving a waste line full for weeks isn't a good thing.Just 2 or 3 inches to get it out of the dirt--how much head is there? Creating a "reverse "P-trap" would require "reverse gravity"--and if you've figured out how to do that what are you doing hanging around here?
