Gastronomique
I have a 80-year-old house in Maryland. There's a drain pipe in the corner of the basement that is below the kitchen sink. The upper 2/3 of the pipe was replaced with PVC before I bought the house. The lower 1/3 is cast iron and rusting and appears quite corroded in a couple spots, but it's not leaking.
I'm going to have the cast iron portion of the pipe replaced by a plumber, and will have him insert a camera into the part of the drain pipe under the concrete foundation to check for further corrosion damage.
I have two estimates from plumbers. One proposes to cut the cast iron pipe just slightly above the foundation and replace it with PVC. The second estimate proposes to dig into the foundation, and remove the old cast iron pipe at the the hub and replace it with PVC. Both plumbers also propose to inspect the remaining cast iron pipe under the foundation with a camera.
My question is, is it much better to dig into the foundation so that the cast iron pipe can be removed at the hub? Or is it equally or almost equally good to remove it just above the foundation? I ask because the plumber who wants to remove the cast iron pipe at the hub is charging $700 more than the one who wants to cut the cast iron pipe just above the floor. The first plumber says the reason to dig into the foundation to remove the cast iron pipe at the hub is to avoid the splitting of the cast iron pipe at the seam, which does appear to be separating very slightly. But if I can save $700 by removing the pipe just above the flooring without causing problems, I would prefer that. It seems one possible way to prevent the pipe from splitting could be to clamp it tightly in three or four places along the pipe with ring clamps. That would only be temporary because once the pipe is removed and replaced, it doesn't matter if it splits or not.
Another question is, how much confidence should I have in a camera inspection of the pipe under the foundation? In your experience, if a cast iron pipe is corroded above the foundation is it also likely to be corroded under the foundation? Or not?
I'm told I'm looking at $7,000 to $10,000 to replace the entire pipe under the foundation and obviously would prefer to avoid that if possible. There is no evidence that the pipe is leaking either above or below the foundation at this time.
I welcome opinions and any suggestions you may have. See the attached photos of the corroded pipe. Thank you in advance.
