Replacement help: Old bathroom sink
Gus64
Active Member
Supporting Member
Mar 6, 2022
31
19087
Hello everyone,
Old bathroom sink cold water handle stem leaks. Either will replace the stem or maybe buy a new faucet altogether. I am guessing it's removed underneath with a plumber's wrench of some sort? It looks like there's rust under there, too. Any suggestions are very appreciated!
Thats a moen faucet and it’s very common.
Grab the fat part of the chrome handle base and turn counterclockwise to remove it. It simply unscrews.
Moen makes a special wrench to remove the internal plastic cartridge retainer nut that’s recessed in the top of the valve. It’s all done from the top side.
Thanks. These handles won't budge at all from the bottom using a basin wrench. I was going to try a pipe wrench on their base up top to see if that loosens them.
That doesn't come off. You have to take it apart at the top to get that part out. If your just replacing the stem
you don't want to take it loose from underneath. Take the handle and the escusion off then you can get to the
stem.
stem.
Ok. The stem just spins freely so I wasn't sure how to 'grab' it.
Yes, as twowaxhack described, unscrew the top fat part (escutcheon) to get to the valve. Sometimes it can't be rotated by hand. You may want to try getting a strap wrench or wrap a dense towel around it and use a pipe wrench to rotate it. Contact moen to get a cartridge for free along with the removal tool. If you send them a picture they may be able to tell you the valve model and provide an assembly drawing of the valve.
The entire valve is removed by unscrewing the large (1-1/4"? ) brass nut on the bottom. By the looks of things, you can get in there with a basin wrench (a cheap one will try your patience) or try one of these:
https://www.homedepot.com/p/RIDGID-...Installation-and-Removal-Tool-56988/303528759
I've found the PBlaster sprayed on the nut sometimes helps or white vinegar.
Good luck
Good luck
It’s a Moen Monticello.
https://www.moen.com/products/Monticello/Monticello-Chrome-two-handle-low-arc-bathroom-faucet/T4570
https://assets.moen.com/shared/docs/exploded-parts-views/t4570pt.pdf
Warning: The handle base unscrews to reveal the inner parts to Moens stupid handle design……
So don’t think the handle comes apart before you unscrew the entire handle assembly from the valve.
Good luck
Thanks. Yes, I tried the basin wrench and no luck. I had that Ridgid in my hand and was about to buy it but thought the other wrench would work and the Ridgid stops at 1 inch. Seems that 1 1/4" brass nut on the bottom will have to be addressed whether I start from the top of the sink or not.
Thank you for this. I am going to send pics to Moen and see what they say, too.
The guy you talk to at moen might’ve been flipping burgers last week. 😂
I'm confused to why you want to take the whole valve out. Are you going to replace that whole thing. You have to get that
chrome escusion off anyway because there is a part undernerath that has to come off to take it apart. Take the escusion off and
take a picture and we will tell you what to do next.
Well, no luck with a pipe wrench so it was time to cut everything off. I am going to replace the whole faucet. I appreciate everyone giving me suggestions and opinions on how to do it! Great forum here!
