Thanks. I tried both without any luck. Note a small ding in a few of the drain holes from the screwdriver. Also would not pry out without bending the drain. I was hoping there was some trick. I'll keep checking for suggestions. Thanks again.Have you tried to gently pry it off, or maybe it threads on put a flathead screw driver in one of the outer holes and tap it left or right to see if it moves
Also I noticed a small hole outside the outer ring of drain holes and wondered if this had any function for removal,Have you tried to gently pry it off, or maybe it threads on put a flathead screw driver in one of the outer holes and tap it left or right to see if it moves
what do you mean by "just to plug the drain"? thanksHave you tried just to plug the drain to clear it??????
I think it's a typo and he meant plunge.
