I need to give some background first. I have a freestanding garage with a 1BR guest apartment over it. It is served by its own well. The well was bored 25 years ago and the pressure tank on it is the original pressure tank. It got a new well pump 7 years ago but is used rarely. We bought the property 15 years ago. Anyway, the previous owner had a single 2" diameter GE sediment filter between the pressure tank and the apartment. The pressure tank is in the garage under the heated apartment, so it does not get below freezing in the winter (North Carolina). The well pumps a lot of sediment. It is large particulate and accumulates quickly in the bottom of the sediment filter housing and the filter cartridge is also quickly clogged up. I'm working on upgrading the filtering, adding 2 more cartridge filters that along with the existing cartridge filter, will give me 3 in-line cartridge filters with progressively smaller filtering, down to 5 microns, and I'm adding a Rusco spin-down filter before the 3 cartridge filters.
To begin the installation, I turned off the pump and isolated the pressure tank to drain it. When I drained the tank, I used a 5 gal bucket to catch the draining water and a LOT of the large particulate sediment drained out into the bucket. I turned the pump back on for 20 seconds and drained it again and repeated this process 10 times, with the pump off for 10 minutes in between each time so I didn't overheat the pump. After 10 times, there still was a lot of sediment coming out of the tank. Since it's already 25 years old, I decided to replace the tank and am waiting on the delivery of a new Amtrol Well-X-Trol WX-250 44-gallon pressure tank.
That's the background. Here's my question: Everything I've read says the spin-down filter should be placed immediately after the pressure tank. But that would allow my new pressure tank to fill with sediment like what happened with the old tank. Is there a reason that I cannot place the spin-down filter immediately before the pressure tank.....between the well pump and the pressure tank, so it catches the sediment before it gets to the pressure tank? And if I cannot do that if you know the technical reason of why not, I'd appreciate an explanation so I can understand the physics. Thanks.
