NoPlumberHere
My pump does not seem to be keeping up with demand. A bit of backstory:
We came home from a walk and noticed a clicking sound. I saw the water pressure gauge fluctuating rapidly and realized the noise was the pressure switch (40-60lb) for our irrigation well - it was cycling very rapidly. Our well pumps to a pressure tank. I turned off the breaker, opened a hose, and measured the tank's pressure, which was zero. OK, bad tank. (It had previously lost some pressure, but I was able to pump it back to 38. And it was ten years old, and it sits the Florida sun. So I wasn't too surprised that the bladder gave up the ghost.)
Based on some advice I got, when I replaced the tank I upsized it, going from 43 gallons to 86. Doing that, I was told, would increase the run time for the pump (larger tank to fill) and would also increase the time between its runs since it takes longer for the tank to empty.
I pressurized the new tank to 38 pounds before filling it, as per its labeling. I turned the power on, and found no leaks in my plumbing - it filled up and held pressure and I saw no water anywhere. But when I turned on the sprinklers, I noticed the pressure dropping to just under 40 pounds and staying there; the pump is now having to run the entire time the sprinklers run. And while I can't swear to it, I am 98% sure that was not the case before; I am almost certain the pump cycled off and on during the sprinkler runs, filling the tank fairly rapidly. Running the pump the whole time the sprinklers are on is definitely not good. We have 9 sprinkler zones (a large yard), and each zome runs for 30 minutes. If I run just a single zone that is probably a 28 or 29-minute period the pump runs constantly, and if I were to turn them all on, the pump would run constantly for 4.5 hours. All that brings me to some questions.
1) Could the rapid cycling that happened (for who knows how long) have damaged the pump so that it no longer has enough power to adequately fill the tank?
and more important
2) What is my next step to diagnose and fix this issue?
Thanks so much for any help or advice!
Mike
and more important
Mike
