Yes it is. I’m in athens. Just west of Huntsville.Is it a manobloc system with the panel of valves in the laundry room or garage ?
What city in Bama ?
Hey, Y'all! I'm over in Guntersville.Yes it is. I’m in athens. Just west of Huntsville.
We’re driving to Nashville today. We’ll be going right by Athens on 65.Yes it is. I’m in athens. Just west of Huntsville.
In post #3 it was determined to be a Manobloc system.Do you have a shut off valve for the toilet. Picture of it please.
Installing a local shutoff would be the easiest way to fix this. Get a 1/2” Pex quarter turn shutoff valve (1/2” crimp Pex, expansion Pex, or push to connect Sharkbite …your choice) and then a standard 3/8” compression to toilet line that can be found in any hardware store and you’re done.I'd still have local shut off's, Manibloc or not!
Manablock uses 3/8" PEX in most cases.Installing a local shutoff would be the easiest way to fix this. Get a 1/2” Pex quarter turn shutoff valve (1/2” crimp Pex, expansion Pex, or push to connect Sharkbite …your choice) and then a standard 3/8” compression to toilet line that can be found in any hardware store and you’re done.
