No Water in Shower
Frank Langer
Dec 13, 2018
14
5
Ohio
I am not getting any water in my shower. I have hot and cold to the sink in that bathroom. I have replaced the cartridge and the balancing valve to the shower. What other options are there?
just the shower head or the tub spout also...…...have you pulled the shower head and turned the water on to the shower arm???????
Should have mentioned, this is a shower only. I have pulled the shower head and did not have water. I also turned water on with the cartridge taken off and did have some water coming through balancing valve, but it definitely was not full pressure water. Once I put the new cartridge back on I get no water.
do you have integral stops....on the shower valve......
I do not have any other valves prior to the shower. I should note that the shower did work previously. It continually got slower and slower and ultimately stopped working period.
can you get a wet vac in there see if you can remove debris where hot/cold enter the valve body
I’ve tried this with no results unfortunately. I have also put a very large wire tie (about 36”) down the pipe that goes to the shower head to try and remove any obstructions. No success there either.
I would suggest pulling the cartridge, and looking for debris of some type blocking the hole in the valve body that leads to the shower riser. Possibly send compressed air from the shower head end to blow out any debris. If you don't have an air compressor, you could also use the exhaust from a shop vac.
Thank you! I have an air compressor and I will try that when I get home from work and let you know the results. Thanks for all your insight!
Thank you to jeffmatero76 and also to everyone else for your assistance. I pulled the balancing valve and cartridge, blew compressed in from the shower head pipe, cleared out debris, and we now have water flowing to the shower again. Much gratitude to all of you. You were all a big help.
