chad K
- Joined
- Feb 28, 2024
- Messages
- 1
- Reaction score
- 0
All, I am installing a utility sink in my garage. I need advice. what you are looking at is my laundry room plumbing from viewing inside the garage. The laundry room is on the other side of the wall. The drain goes into the basement.
1. Can I put a "T" where I circled cut and drain into this?
2. I want the sink positioned where it sits or a little to the right. I was thinking of running the horizontal section on the outside of the wall so I dont have to cut into the wall studs. Any issues with this?
3. hot/cold water supply - do I need to do anything special about protecting the pipes from freezing? Even in worst conditions the garage never gets below freezing inside.
