harryinca
This is a copy of my email reply to Harryinca (Jack in Sacramento); I am posting it since it might be helpful to anyone else who has a similar problem:
The replacement parts should be positioned under the cap in the photo where the tank ball pivot is located. All you have to do is remove the two stainless steel screws, remove the cap, replace the parts (I think it was a plastic plunger and a diaphragm but I can't remember exactly what the parts were), replace the cap, and you're in business. Duck soup. Good luck.
Thanks! So you are talking about these two screws? Do you have to lift the entire fill valve out in order to replace that 3/4 valve wrapped in black?
I have already had experience removing the screw that regulates the diaphragm height. I haven't tried removing that screw in the center, but it looked to
me like the whole assembly goes all the way to the bottom of the tank. So when you say the "cap" comes off, it's just the copper top to the left of the piece with the two screws?
