rufon
I had my hot water tank replaced and the plumbers used hex pipes to connect the hot/cold water. Since then I had a couple other plumbers come in to do some other work (not related to the hot water tank) and they mentioned that using PEX pipes are not up to code and it should be copper pipes. I have had a difficult time contacting my original plumber who did the installation to ask if this is actually true. I have attached a pic of the install.
Please let me know if this is up to code or not. Thank you
