No, you are a special kind. Lol!
I have no doubt you think you are brilliant. Me, on the other hand, I don't claim to be brilliant, just got lucky. I came up with the idea for the Cycle Stop Valve by accident, and 30+ years later I am still figuring out all the amazing stuff it does.
The external bypass is what others who were trying to copy me used before my patent expired. Now they make them EXACTLY like a Cycle Stop Valve. Flomatic has made a big business copying everything I do, and they make no bones about it. They still have one holdover valve with an external bypass, but nobody uses that one as we all know the bypass clogs. They also make a copy of the Dole valve, which is the link you gave. The rubber thing in a Dole valve does help, but any of them less than 2 GPM still clog. It is making the drilled hole bypass large enough not to clog that is the key. But the larger the bypass defeats the purpose of eliminating the cycling at low flow. Since they copy me exactly I will give them a boost and post the link here.
https://www.flomatic.com/valves/constant-pressure-pump-control-valves/
No matter if you make an exact copy or figure out someway to keep an external bypass from clogging, at least you have realized the Cycle Stop Valve idea is a far superior way to control a pump than any other way on the market.
PS. I told your wife I was not interested. Lol!
