Can Someone Clarify the Use of Feminine Pads in Sweating Copper
sburtchin
Active Member
Feb 9, 2015
40
My dad worked for a privately owned plumbing contractor with about 100 employees. I can remember him telling me that the 'copper' guys used feminine pads to hold back (absorb) the water while sweating copper. I thought he said they left it in the pipes. Is the whole pad used, or just the stuffing? Does it have to be a particular brand? Is this technique only used for waste lines, or can it be used on supply lines too?
Please clarify this technique. Thanks.
:eek:
Never heard that one before. But you don't want to leave it in.
White bread , no crust, is a more common trick of the trade.
First time I did it was in a crawl under a house. Stuffed it good.
Made repair.
Turned water back on.
NO water downstream of repair. :mad:
To much bread. Had to cut repair and dig out the bread.
Try again.
Not so much bread next time around.:eek:
I can clarify. you are getting facts backwards, tampons are referred to as "sewer mice" because the string looks like a tail. sewer mice are found in drains not water pipe
no way, I will repeat this . NO WAY, would you leave a femine product in a copper pipe.
their is a chemical, in side the product that is very/super absorbant, it is also used as a fire retardent by fire fighters.
it would stop up the pipe.
the only thing I have ever put into a pipe and left, is bread, it breaks down into sugar and dissolves
