Ok, thats my thoughts as well, but now I would need a bolt remover to remove that correct? If you probablly can guess, I'm trying to save myself from calling a plumber and would like to DIY.You could take the good handle to a plumbing supply house and the will probably match something up
Are both handles stuck on????? Spray them with wd-40 or something like that, let it sit overnite when you get the screws out tap the handles away from the stem they should come off measure center to center of the faucet unions, yo may find something that may fit central brass is a brand that made those faucets
For a temporary fix, you could pack a bit of steel wool in the handle and jam it back on.Ok, thats my thoughts as well, but now I would need a bolt remover to remove that correct? If you probablly can guess, I'm trying to save myself from calling a plumber and would like to DIY.
