Banging noise from copper pipe in the attic
sweet_home
Jun 10, 2010
We are doing some energy improvements in our house. The insulation in our attic was completely removed and attic air sealing work was completed today morning. Since today we have been noticing a noise for a few seconds (more like a knocking/banging noise) whenever we open the hot water in one of our bathrooms. This bathroom is the only place to which the pipe goes through the attic(rest of the house has plumbing through the crawl space) This happens only for the first time when we open the tap. We don't hear the noise if the tap is opened frequently right after the first time. However, the noise is back if we wait for a long time(may be an hour or so) and then open the tap again. My husband went up the attic to make sure that everything was ok with the pipe. He feels that the copper pipe is expanding and that's what is probably causing the noise as it is nailed to the stud and probably rattling against it. I am very confident that we are hearing this noise because something changed after the folks went up there for the air sealing. Otherwise we would have heard this noise all along and not just starting today. Could there be anything that might have been displaced? Are there any fittings around the copper pipe( that typically mask the expansion/contraction noise) that could have been accidentally moved or removed while walking over the pipes? Before I run about calling a plumber to come and take a look, wanted to check with the knowledgeable folks in this forum. Would really appreciate if folks can provide any pointers. Thanks!
The insulators couldn't possibly have removed anything....except for straps and clamps. But your saying its pretty well secured. Hard to say what exactly is causing your noises.
Water hammer is generally created when closing a valve not opening. So yeah it could be expansion. It could also be that it has always been happening but the insulation was protecting it from making noise.
Are you in a temperate climate?
