Automated Tank Transfer System
mwmariner
Feb 25, 2022
Northern Michigan
Hi there everyone,
I am working on a miniature automated tank transfer system using a plc and relays. I am using a seaflow 24v diaphragm pump to move the water from a main reservoir to one of four tanks. Sometimes at the same time. I am using solenoid operated (NC) washing machine inlet valves for both my suction from reservoir to my pump, as well as discharge back into the reservoir. Then I have a 4-valve (same type washing machine solenoid valves) for my inlet to the tanks and discharges from the tank. I have run it one time for 5 minutes just now. (Note to self: My downstairs roommate doesnt like the sound of the pump at 2300. Should have thought of that but I was too damn excited to see the thing work.) With that said, I am a little worried about my choice to use the washing machine valves as my discharge valves. They seem to be leaking by. Though I have one tank full and it is staying at its level. Not sure if the pump operating is creating a low pressure that is allow water to sneak through during operation.
Does anyone have any thoughts on this matter?
Thanks in advance!
If the washing machine valves are leaking by then they’re probably defective.
