Angle valve sizing question?
gendow
Feb 26, 2015
76
18
Other than ice maker tubing which is 1/4" compression, what are the different sizes for angle valves? And how can you decipher the size of it other than years of experience of just looking at it. These are what I know of;
3/8" compression
1/2" compression
1/2" IPS (and is F.I.P. interchangeable with I.P.S.)
3/8" compression
1/2" compression
here is some info we discussed about tubing size.
1/2" IPS is Iron Pipe Size. FIP refers to female iron pipe size and MIP to male iron pipe size.
http://www.plumbingforums.com/forum/showthread.php?t=6986
Water pipe - Wikipedia, the free encyclopedia
From Wiki :
Water pipe
the way it is sized. PVC pipe for plumbing applications and galvanized steel pipe for instance,
are measured in IPS (iron pipe size). Copper tube, CPVC
different types of valves
globe valve
plug valve
ball valve
gate valve
butterfly valve
needle valve
check valve
solenoid valve
full port valve
different connections are, flanged, threaded, glued, compression,
WOG marked/stamped on a valve means, water, oil, gas
