Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Cannot remove Zone Controller
Thread Tools Display Modes
Old 06-13-2014, 05:06 PM   #1
jolleyi
Default Cannot remove Zone Controller
Hi, I have a gas fired boiler for a hydronic heating system. I have 3 zones using Honeywell V8043F control valves. I recently replaced one which the guy servicing the boiler said had a short (it was sparking) and all is well with that zone.
When the guy was servicing the system he took off the powerheads and lubed the valve stems, all except one powerhead which would not come off. Has anyone experienced this?
I can take out the 2 screws which hold the powerhead onto the valve body and wiggle it from side to side but it will not come off. (usually these just lift off easily).
I have been very careful not to get too rough with it as i do not want to damage the valve and have to sweat a new one in place.
Any ideas?
jolleyi is offline
Old 06-14-2014, 12:09 PM   #2
DFBonnett
Liked 17 Times on 14 Posts
Likes Given: 22
Do you have the manual lever in the open position?
DFBonnett is online now
Old 06-14-2014, 09:28 PM   #3
jolleyi
I've tried it in the open and closed position, (using the lever), the result is the same.
thanks
jolleyi is offline
Old 06-14-2014, 10:00 PM   #4
johnjh2o
johnjh2o's Avatar
Liked 722 Times on 546 Posts
Likes Given: 615
If I'm not mistaken there is a small clip that fastens the motor to the stem that has to be removed.
John
johnjh2o is offline
Old 06-19-2014, 02:22 PM   #5
jolleyi
No clip, but i dismantled the power head and found the black plastic part was damaged, causing it to sit at an angle. Assume this was the problem.
Back in business with a new powerhead.
jolleyi is offline
Low pressure on one sprinkler zone mfurey14 General Plumbing Help 6 03-31-2014 05:40 AM
Thermasol generator with Kohler DTV II controller rkesner Showers and Tubs 1 06-25-2012 01:50 PM
heating zone heats up when it should not notaplumber General Plumbing Help 1 09-21-2010 02:56 PM
Amtrol Digital Controller/Switch for Well Pump Kawiski Pumps and Wells 2 07-23-2010 02:16 PM
Shower Controller replacement problem Golfish Showers and Tubs 1 01-23-2010 10:25 PM
Newest Threads
