Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Showers and Tubs > Shower drain pipe came loose
Thread Tools Display Modes
Old 04-04-2014, 11:52 PM   #1
twobiscuit
Default Shower drain pipe came loose
I have a fiberglass shower in my master bathroom. I am also on a slab. The other day I noticed water coming out of the ground onto the concrete slab beside my house. I called a plumber and we/he found that the pvc drain pipe had come loose from the drain on the shower. It has dropped down aproximately 1" from the bottom of the drain. After multiple attempts, the plumber and I sucessfully got the pipe back in the drain and tightened back up. Now, two days later, it has come loose again due to me and my wife standing on the floor of the shower. It must move just enough that the o-ring and flange nut won't hold it in place. I am not sure how long it has been leaking, but the dirt below the slab has been washed away allowing the pvc pipe to sag causing it to be very difficult to keep in the shower drain. The only real option I see is to cut the pvc pipe with an inside pipe cutter, add a coupling and a length of pvc pipe, and install a wingtite drain. My question is, has anyone had this happen? How did you repair it? Does the wingtite work pretty well? I really don't want to have to cut my concrete foundation as that would be a major undertaking. I look forward to your replies and thanks in advance for your help.
Doug
twobiscuit is offline
Old 04-05-2014, 01:58 AM   #2
johnjh2o
johnjh2o's Avatar
Liked 726 Times on 550 Posts
Likes Given: 620
The wing tight will work. But before installing it get the PVC pulled up to the correct height. Then pour some cement around it to hold it in place.
John
johnjh2o is offline
Old 04-05-2014, 07:59 AM   #3
twobiscuit
Would you use the wingtite or the Davke 4000 drain? With the Davke, I would have to epoxy the drain to the fiberglass shower. I probably would never have to remove the drain but with the epoxy it definitely would not be an easy task if I did.
Loose bathtub drain Shyda Showers and Tubs 2 03-02-2014 02:30 PM
Toilet PVC drain pipe came loose from pipe that leads to sewer. tireshark General Plumbing Help 6 08-02-2011 01:20 AM
Loose Water Supply Pipe - should I worry? jebber45 Toilets and Sinks 12 05-13-2011 01:38 AM
Shower Drain Pipe Help bhinhb General Plumbing Help 0 03-28-2011 08:43 PM
Loose Drain Pipe Below Kitchen Sink :( DukeStratosphere General Plumbing Help 5 02-17-2011 07:10 AM
Newest Threads
