Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Copper lines through slab under dishwasher
Thread Tools Display Modes
Old 03-26-2014, 01:36 PM   #1
bthawkins
Default Copper lines through slab under dishwasher
I am remodeling my kitchen after recent water damage and have purchased a new dishwasher to replace the damaged one. When I pulled out the existing dishwasher, I discovered the copper supply lines for the sink come through the slab under the dishwasher almost 10 inches off the back wall. The horizontal run of the pipes is 2" above the slab. I have no idea why the house was built this way. My 10 year old dishwasher cleared the pipes, but my new one and a few other new ones I've looked at have so many components mounted underneath that they won't clear the copper pipes even with the dishwasher raised as high as possible. What can I do?
Tear up the slab to move the pipes 10"? I just had new cabinets installed, but could pull out the sink base unit relatively easily.
Start crawling under dishwashers at Lowes to try and find one that 'might' fit?
bthawkins is offline
Old 03-26-2014, 10:05 PM   #2
Matt30
Liked 643 Times on 487 Posts
Likes Given: 184
Cut out the copper and use a braided dishwasher supply hose.
Matt30 is offline
Old 03-26-2014, 10:30 PM   #3
johnjh2o
johnjh2o's Avatar
Liked 692 Times on 526 Posts
Likes Given: 579
Quote:
I think he needs those lines as they feed the kitchen sink.
John
johnjh2o is offline
Old 03-26-2014, 10:42 PM   #4
MrCitywide
MrCitywide's Avatar
I would cut the copper lines down as low as possible to the slab and tie them back to the existing lines behind/inside the cabinet if you don't want to chip up concrete
Sent from my iPad using Plumbing Forum
MrCitywide is offline
Old 03-26-2014, 10:43 PM   #5
MrCitywide
MrCitywide's Avatar
Or just cut Sheetrock and offset inside the wall as low as possible and come back out of the wall inside the cabinet maybe????
Old 03-26-2014, 10:47 PM   #6
MrCitywide
MrCitywide's Avatar
Aaaaaahhhhh! Never mind I see it now, the picture is small on my iPad. Yea looks to me like your going to have to bust concrete
Old 03-27-2014, 12:01 AM   #7
bthawkins
Yes, I haven't come up with any other solution. I pulled out all the dishwashers at HD and one other store that weren't fastened into the displays but didn't find a workable one. The manufacturers really use all of the available dishwasher footprint now; the same brand as my old one wasn't even close to fitting. I'm going to make the permanent fix and pull the sink cabinet, cut 18" out of the slab, and move the lines.
Old 03-27-2014, 07:33 PM   #8
Matt30
Likes Given: 184
Quote:
I misunderstood i was under the impression they were being fed from the sink side
Matt30 is offline
Help Installing Dishwasher elisa73 Toilets and Sinks 4 12-30-2013 03:26 AM
Unidentifiable copper pipes protruding from slab... trophft General Plumbing Help 11 10-20-2013 02:19 PM
Plumber installed sink, pipes, dishwasher, icemaker lines, not working taylorsmommie Toilets and Sinks 3 02-02-2012 12:19 AM
type M copper splitting on heating lines.. LiQuId Water Heaters and Softeners 5 08-17-2011 10:25 PM
Moving Drain in Slab & Copper Lines In The Way Higgy General Plumbing Help 4 05-07-2011 05:04 AM
Newest Threads
