Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Help Removing Steam Pipe
Thread Tools Display Modes
Old 07-31-2013, 01:46 AM   #1
steveh3134
Likes Given: 2
Default Help Removing Steam Pipe
Any ideas on how to remove the pipe in the attached image? By pipe I mean the one sticking up vertically out of the floor.
When I was taking the valve off I crushed it and now the end of the pipe is out of round so there's no way I'm going to be able to get a new one on. So I feel like my only option is to replace it.
I tried getting a pipe wrench on there but it's up kind of high and hard to get any leverage. I thought about cracking the elbow but as you can see from the image, there isn't a lot of room down there because it's right up against a joist so I'm concerned that I won't be able to get a new elbow on.
Thanks in advance.
/Steve
steveh3134 is offline
Old 07-31-2013, 02:04 AM   #2
johnjh2o
johnjh2o's Avatar
Liked 723 Times on 547 Posts
Likes Given: 616
Steve is there any play in the line can it be lifted? If it won't unscrew your other option is as you stated is to crack the ell. They do split fairly easily. You will need to get something under it to support it. Once it's supported a couple good whacks on the boss of the fitting should crack it. Once it's cracked it will spin off by hand.
John
johnjh2o is offline
steveh3134 Likes This
Old 07-31-2013, 03:27 AM   #3
chukar
Liked 20 Times on 18 Posts
2nd option HEAT, wrap the area in wet rags, put your torch on the elbow and heat it up, then use an offset wrench on it.
chukar is offline
Old 07-31-2013, 01:16 PM   #4
steveh3134
Likes Given: 2
Hi guys, thanks for the suggestions. Still weighing my options before I move forward. If anyone thinks of anything else, let me know.
Old 08-02-2013, 05:49 PM   #5
steveh3134
Likes Given: 2
Default how many turns
Hi all, what's the rule of thumb to follow when putting the new ell and nipple back on? I was thinking some pipe dope, hand tighten, and then 2 full turns with a wrench?
Old 08-02-2013, 08:07 PM   #6
johnjh2o
johnjh2o's Avatar
Likes Given: 616
There is no rule of thumb. Depending on the manufacture some threads are cut deeper than others. It's done by feel more then anything else. Keep in mind that with steam your not dealing with that high of a pressure. Just use a high temperature pipe dope and you'll be fine.
John
johnjh2o is offline
Ariel Platinum steam shower.. should I buy? islandgirl Showers and Tubs 8 01-25-2013 07:24 PM
Steam radiator issue... theskunk General Plumbing Help 1 01-21-2012 01:02 PM
Steam Radiator jchiz General Plumbing Help 6 07-25-2011 10:03 AM
Single pipe steam radiator question beck General Plumbing Help 1 03-18-2011 08:49 AM
Newest Threads
