Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > leaking pipe under the wash basin.........
Thread Tools Display Modes
Old 12-20-2012, 07:28 PM   #1
Windy
Liked 19 Times on 18 Posts
Likes Given: 24
Default leaking pipe under the wash basin.........
Okay, my plumbing princes, I have another small project and more questions.
I hope I can describe this well. I don't know the terminology.
I have a double sided washbasin next to my washing machine. There has been a time or two that my washing machine is unbalanced and 'takes a walk'. During one of these events, my washer 'walked' into the wash basin and pushed it a little. The wash basin is very old, two sided. It appears to be a cement filled metal basin on a heavy duty metal stand. (Does that make any sense?) Each side of the wash basin has a drain that meet directly under the tubs and goes down one drain pipe. Well, because the basin has been pushed, there is now leaking in that drain pipe under the basin. It is PVC pipes under there. I'm not sure if the leaking is coming from the connection where the drain pipe actually connect to the tub or if it's further down. I am going to attempt to repair this myself. Am I going to need any special tools to work with the PVC pipe?
In a little bit, I'll go downstairs and try to take some pictures because I'm sure you all might have trouble understanding the situation by my description. Fortunately this whole set up is directly over the floor drain and I'm still using my washing machine. As the water leaks out of the basin it just goes right down the floor drain with very little mess. But I'd like to get this running correctly soon.
Windy is offline
Old 12-20-2012, 09:20 PM   #2
havasu
Administrator
havasu's Avatar
Liked 1114 Times on 906 Posts
Likes Given: 334
Before giving you bad advice, a few pictures would sure help us.
havasu is offline
Old 12-20-2012, 09:58 PM   #3
Windy
Likes Given: 24
Okay. I'll see what I can do. I'm old and it'll take me 15 minutes to get down on the floor to take the pictures, probably 30 minutes to get back up off the floor and a good 12 hours or so to prepare to get on the floor to take pictures.
Windy is offline
Old 12-20-2012, 11:44 PM   #4
havasu
Administrator
havasu's Avatar
Likes Given: 334
Now I feel bad! (not )
havasu is offline
Old 12-21-2012, 12:08 AM   #5
KULTULZ
Jack of All Trades ~ Master of None
KULTULZ's Avatar
Liked 316 Times on 277 Posts
Likes Given: 172
Quote:
My problem is once I get down, I feel the need for a quick nap...
- PLUMBER'S GUIDE TO SUCCESS -
1) Hot On Left - Cold On Right
2) Shiat Flows Downhill
3) Lefty Loosey - Righty Tighty
4) Do Not Bite Nails
5) Plunge With Mouth Closed
6) Leave No DNA On Job Site
7) Just Say No To Plumber's Crack
8) Boss is PIA - His Wife Is Looker
9) Payday On FRI
10) There Is NO LH Monkey Wrench
KULTULZ is offline
Windy Likes This
Old 12-21-2012, 12:57 AM   #6
phishfood
Administrator
Liked 964 Times on 775 Posts
Likes Given: 1739
If it is tubular (thin wall) PVC, it very likely is cracked.
Pictures would definitely help.
Lake County, Florida plumber
Springtime Plumbing Services
phishfood is offline
Old 12-23-2012, 03:55 PM   #7
DetroitRob
DetroitRob's Avatar
Liked 11 Times on 11 Posts
Hopefully you can just tighten a jamb nut on the pvc and not have to get into a leaky strainer. They can be a pain for a non pro, especially on an old cement tub.
DetroitRob is offline
Old 12-23-2012, 03:56 PM   #8
havasu
Administrator
havasu's Avatar
Likes Given: 334
Shhh. Windy is still napping.
havasu is offline
Old 12-25-2012, 08:01 PM   #9
Solid
Liked 5 Times on 5 Posts
Likes Given: 6
Windy,
I feel your pain, believe me! I bet your utility sink looks like this beauty:
This is the only picture I have that shows any of the plumbing under the tub:
Now, almost all of the PVC plumbing in this photo is wrong, and has been replaced, so try to ignore all of the white pipes. My old tub had signs of leaking where the tail pipe connected to the bottom of the wash tub. that piece was brass (or copper) and had 2 bolts that connected it to the bottom, and I believe a gasket. I would check that spot, and the trap connections. I ended up replacing the entire thing, because one of the tubs was cracked, and I had to fix all of that plumbing anyway. This is what it looks like now:
Post some pictures as soon as you can - the members of this forum are incredible, and will get you fixed up in no time!
Solid is offline
phishfood Likes This
Old 12-26-2012, 05:16 PM   #10
KULTULZ
KULTULZ's Avatar
Likes Given: 172
Do not mean to this thread, but there are a few questions-
1) What type of trap is that and where is it recommended to be used?
2) Neither the washer discharge or the sump pump discharge were trapped?
3) That is a double bowl sink. Why is there only one drain outlet?
A Continuing Learning Curve In W (BY GOD V)...
9) Payday On FRI
KULTULZ is offline
hot H20 pipe leaking... P14224 Water Heaters and Softeners 4 12-20-2012 01:28 AM
Help! connection to kitchen faucet hose/pipe leaking pineapple808 Toilets and Sinks 4 08-18-2012 11:15 PM
wash machine drain clog & kitchen sink... UncleBen Drain and Sewer Cleaning 4 11-07-2011 12:07 AM
Modify the PVC pipe under the wash hand basin yslhm General Plumbing Help 5 06-22-2011 05:04 AM
toilet leaking into overflow pipe bridgeboy Toilets and Sinks 17 02-27-2010 07:06 AM
Newest Threads
