Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Toilets and Sinks > Odor from toilet tank
Thread Tools Display Modes
Old 12-04-2012, 01:02 AM   #1
Default Odor from toilet tank
I do facilities work at a large veterinary hospital and I'm troubleshooting an odor that's coming from one our toilets. It's almost a sewer smell but not quite the same. After checking I found that it's not coming from the base or from the inside of the bowl. It is very concentrated in the actual tank (as unusual as that sounds). I've already removed the tank and the pressure tank from inside of it (It's a Flushmate equipped toilet) and cleaned and disinfected the inside but the smell has returned after a couple days. Any ideas of what might be the cause?
Rhooligan is offline
Old 12-04-2012, 03:29 AM   #2
johnjh2o's Avatar
Liked 729 Times on 553 Posts
Likes Given: 624
When you have a sewer gas leak it is very hard to locate the source. Unless you do a smoke test. In your case I would replace the wax seal as this the #1 source for sewer gas leaks. If for nothing else just to eliminate the wax seal.
johnjh2o is offline
Old 12-04-2012, 04:43 AM   #3
stevemachine's Avatar
Liked 115 Times on 99 Posts
Likes Given: 97
Yeah if it's only from one toilet it couldn't be to do with the water. Sometimes this stuff is a shot in the dark without doing tests like John said. I agree and say replace the wax seal to start.
stevemachine is offline
slow filling toilet tank abfab Toilets and Sinks 2 08-18-2011 10:50 PM
Toilet Tank Leak - Cracked Tank? RobZ General Plumbing Help 5 11-09-2010 11:50 PM
odor from toilet sfloresfour General Plumbing Help 12 09-22-2010 12:12 AM
Toilet tank will not fill. cnl390 Toilets and Sinks 2 08-01-2010 03:12 PM
High Tank Toilet Stopper eorns Toilets and Sinks 3 07-21-2010 01:18 AM
Newest Threads
