Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Pumps and Wells > Issue w/ well pump, pressure tank or pressure switch???
Thread Tools Display Modes
Old 10-26-2012, 07:25 PM   #1
pmoney1983
Default Issue w/ well pump, pressure tank or pressure switch???
Here is what is going on with this persons well setup:
When water is in use from a faucet, the water flows correctly for the first 2 to 3 seconds, then the flow of water drastically slows down to almost nothing, then it picks back up within a few seconds again, and continues to flow at a resonable flow rate. Any ideas?
I am thinking its the pressure switch, I dont believe it has anything to do with the pressure tank failing, as that usually makes the pump contiously run.
Thanks for your help.
pmoney1983 is offline
Old 10-27-2012, 02:48 AM   #2
waterwelldude
Water well,and septic guy
waterwelldude's Avatar
Liked 4 Times on 4 Posts
Likes Given: 1
It sounds like the tank may be waterlogged. If its a bladder tank check the air in the tank.
It should be 2 to 3 psi less that the pressure switch cut on pressure. if its not a bladder tank, drain the tank dry, that will
give it a fresh start. Also check the line going to the pressure switch as sometimes they get clogged with minerals and need to be cleaned out.
If all that checks out, watch the pressure switch. If the pressure drops way down before the pump kicks in
it may be time for a new switch.
Edit Signature
waterwelldude is offline
Old 10-27-2012, 01:48 PM   #3
speedbump
Wells & pumps; not a...
speedbump's Avatar
Liked 211 Times on 192 Posts
Likes Given: 46
Actually it makes most pumps cycle on and off rapidly. Submersible pumps especially.
speedbump is offline
Piston pump & pressure tank? beerman Pumps and Wells 17 04-07-2016 01:05 PM
Will Increasing Pressure Tank Size, Increase Pressure? TxBuilder Pumps and Wells 8 07-13-2012 05:18 AM
Pressure switch/well pump issue? ah55 Pumps and Wells 6 02-26-2012 12:03 AM
Pressure Switch or Pump problem? ericivins Pumps and Wells 7 01-17-2012 09:41 PM
Pump/pressure tank detective needed ngermain Pumps and Wells 1 05-05-2011 03:59 PM
Newest Threads
