Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Plumbing Tools and Equipment > Sharkbite vs Crimp?
Thread Tools Display Modes
Old 05-25-2012, 03:33 AM   #1
H20Boy
Default Sharkbite vs Crimp?
Who is a fan of what and why?
I would like to hear the pros and cons to applications if possible.
H20Boy is offline
Old 05-25-2012, 03:57 AM   #2
havasu
Administrator
havasu's Avatar
Liked 1063 Times on 859 Posts
Likes Given: 297
I prefer Sharkbite as a temporary fix and a crimp as a permanent solution.
havasu is offline
Old 05-25-2012, 04:12 AM   #3
LiQuId
Liked 15 Times on 11 Posts
Likes Given: 20
sharkbite is awesome if in an accesiblle place, that is the only place it should be used.
crimp, 100% better than sharkbite and will last and not fail .
LiQuId is offline
Old 05-25-2012, 12:34 PM   #4
johnjh2o
johnjh2o's Avatar
Liked 701 Times on 533 Posts
Likes Given: 589
Quote:
This is were my vote goes.
John
johnjh2o is offline
Old 09-10-2012, 01:53 AM   #5
PioneerPlumber
:0)
PioneerPlumber's Avatar
Liked 21 Times on 21 Posts
Likes Given: 5
Quote:
John
I agree again 100%. Shark bite or "tektite" fittings are temporary fixes only. That goes for anything that has an o-ring seal for that matter. I stock them in my trucks for temporary use only. And the caps work great for demo situations!
Rock on John
-Daniel
PioneerPlumber is offline
Old 09-27-2012, 01:56 AM   #6
cjn79
Liked 1 Times on 1 Posts
Same with me. I like them on freeze ups in the middle of the night because they are fast and easy but I consider them temporary as well. I've only had one fitting leak but just don't trust them longevity wise yet.
cjn79 is offline
Old 11-11-2012, 09:09 AM   #7
seak
what about pro press? same thing isn't it?
seak is offline
Old 11-11-2012, 12:28 PM   #8
phishfood
Liked 939 Times on 755 Posts
Likes Given: 1679
Though I haven't used ProPress, I do believe that the fittings have an Oring inside. The press tool crimps the copper fitting against the outer wall of the pipe, making a ridgid connection, unlike the SharkByte fitting, which has some movement to it. This makes it probably a better fitting than a SharkByte, but I still question ProPress in a long term situation. Time will tell.
Lake County, Florida plumber
Springtime Plumbing Services
phishfood is offline
Old 11-21-2012, 07:24 PM   #9
Crackplumbers
Crackplumbers's Avatar
Liked 2 Times on 2 Posts
Shark bite is much more expensive than other methods of joining, but can mate two totally different material types as long as the outside diameter is the same. It also works well if the liquid in the pipe can not be stopped or can not be turned off. Shark bite has not been around long enough to prove itself as a long term solution.
Crackplumbers is offline
phishfood Likes This
Old 11-23-2012, 01:29 AM   #10
jack
Both are for the home owners and want to be plumbers. Real plumber use copper
jack is offline
copper crimp ring v/s s/s cinch clamps jocar General Plumbing Help 1 03-20-2012 09:58 PM
no- solder joints sharkbite connections bucktooth General Plumbing Help 2 11-25-2011 01:45 AM
Sharkbite fittings mprong General Plumbing Help 5 09-04-2011 05:29 PM
SharkBite DBCooper1996 Plumbing Products 8 03-19-2011 11:41 PM
Newest Threads
