Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Plumbing Tools and Equipment > Soldering copper pipe with heat gun? What about brass?
Thread Tools Display Modes
Old 02-24-2017, 05:52 AM   #1
kotterr
Established Member
Default Soldering copper pipe with heat gun? What about brass?
Is it possible to connect copper pipe by solder using a heat gun instead of a torch? I know a heat gun can quite easily melt a bar of tin down to a puddle and it would have likely done the same with the lead bar I had in there had I not dropped the entire piece in there (solder is used in MUCH smaller quantities). But can it work to solder copper pipe together? What about brass to copper?
https://www.amazon.com/Astro-9425-Du...dp/B00MAB80EU/
kotterr is offline
Old 02-24-2017, 06:27 AM   #2
Nehmo
Established Member
Nehmo's Avatar
Liked 3 Times on 3 Posts
Likes Given: 1
Quote:
Originally Posted by kotterr View Post
Is it possible to connect copper pipe by solder using a heat gun instead of a torch?...
Yes, you can solder with a heat gun, and under some conditions, it's preferable. There's an attachment that helps contain the heat.
Nehmo is offline
WorkingStiff Likes This
Old 02-24-2017, 06:59 AM   #3
WorkingStiff
Established Member
Liked 2 Times on 2 Posts
Likes Given: 4
Quote:
I would have thought no, given that copper is such an effective heat sink. It must be incredibly slow though right? Still work with larger sections of pipe? (that is a pretty short section there).
WorkingStiff is offline
Old 02-24-2017, 07:36 AM   #4
SHR
Liked 282 Times on 214 Posts
Likes Given: 776
No. And the fitting in the pic is a type known for failure. For safe and reliable connections, no heat gun for soldering and no pre-soldered fittings. I realize some will argue but I have seen them fail regularly. Heat gun soldering and pre-soldered fittings ARE good for increasing my bank account due to frantic calls from homeowners to fix their leaking joints. They always say they "saw it on the internet, so why didn't it work?"...
SHR is offline
People Like This
Old 02-24-2017, 11:20 AM   #5
frodo
Just call me Macgyver
frodo's Avatar
Liked 1844 Times on 1573 Posts
Likes Given: 381
Quote:
agreeing with SHR
My advice is free, If I have helped you and you wish to help the site out with a gift
use this link
http://www.plumbingforums.com/forum/...faq=supporting
frodo is offline
SHEPLMBR Likes This
Old 02-24-2017, 06:42 PM   #6
Matt30
Liked 729 Times on 552 Posts
Likes Given: 198
Why would you want to do this? Its 10x easier and safer to use a propane torch and proper fittings
Matt30 is offline
SHR Likes This
Old 02-24-2017, 06:44 PM   #7
Matt30
Likes Given: 198
Also, who solders a coupling onto a pipe in a vice???
Matt30 is offline
Old 02-25-2017, 01:42 AM   #8
kotterr
Established Member
I saw that video, too. No, I wasn't about to use presoldered fittings. Sounds expensive and you don't get to apply the solder to your satisfaction. I was just wondering if it were doable in a situation where I did not want to have an open flame. Does anyone have any personal experience with doing it with a heat gun?
Also, what about soldering copper to brass or to stainless steel? Is it possible? Would I need something hotter, like MAPP gas?
kotterr is offline
Old 02-25-2017, 04:45 AM   #9
Matt30
Likes Given: 198
You can solder copper to brass without issues. You cannot solder stainless steel. If you are worried about open flame, get yourself a heat shield of some sort. Ditch the heat gun idea, trust me. Its going to be way harder.
Matt30 is offline
Old 02-25-2017, 11:11 AM   #10
Nehmo
Established Member
Nehmo's Avatar
Likes Given: 1
Pre-Soldered Fittings use an alloy of solder that melts at a lower temperature than standard solder. Since a typical electric heat gun supplies much less heat than a torch, to get the job done in a reasonable time, the heat gun demonstrator chose to use a Pre-Soldered Fitting.
The merits of such fittings are debatable, (and that discussion deserves a thread of its own), but I wonder if those who had trouble with Pre-Soldered Fittings hadn't yet gotten the hang of them. With a Pre-Soldered Fitting, you heat the pipe more than the fitting. That's the opposite of the usual technique.
The other issue is the brass you asked about. While brass’s affinity to copper (actually brass is an alloy of copper and zinc) presents no problem, the thickness of the brass fitting may. Often a brass fitting is much thicker than the copper pipe it joins to. The thicker a fitting, the more heat it requires during the soldering process, and the weak electric heat gun may tax your patience.
You might consider practicing a little on some scrap pipe and a few extra fittings. Before you do your actual project, you should be confident in your own ability to succeed.
I don't know what of your situation makes you want to avoid the flame, but I assume it's a legitimate concern. If there's flammable material in range, get it wet first, and protectively cover it with something. A precautionary water hose wouldn’t be a bad idea too.
If you really want to be cool, get a 5 kilowatt power supply, and learn
Nehmo is offline
Mr_David Likes This
Failing copper joins during soldering bawldiggle General Plumbing Help 29 03-19-2015 03:22 AM
Copper sweat soldering question JIMMIEM General Plumbing Help 3 10-16-2014 12:57 PM
How to clean copper pipe after soldering Fusion916 General Plumbing Help 6 08-07-2013 05:27 PM
Soldering copper pipe in tight location- Help Needed Pics included amodoko General Plumbing Help 26 08-16-2012 12:24 AM
pinhole leaks in copper pipes - soldering catpace Showers and Tubs 3 05-11-2010 05:11 PM
Newest Threads
