Hello everyone,
I am building car washing bay and need advice what type of pumping system i have to choose.
Basically water inlet will be flush with the ground. We have a concrete ramp where piping is installed.
We need totally 2 pumps: 1st where the water enters, pump needs to pump the water into oil/water separator. 2nd pump is when water is filtered, it needs to be pumped vertically up and then horizontally to the final drain.
Here is the image scheme to make it easier. Can anyone recommend best solution/pump types/links maybe? Can we use just a pumps without any additional collection tanks? BTW: water will not be constant, i mean that inlet will either have water or not, depending we washing the car or not. I assume we need pump with some control module that it only turns on when water is detected.
Thanks!
Thanks!
