i made a video explaining my problem and showing the drain system in my house
1969 split level home. i'm a novice trying to find the clog.
Have a main floor drain in basement near the washer dryer which has a 3 ft pipe sticking out the floor that i put the washer drain hose into. Also have what i think is called cleanout 2 feet above floor in the basement near the wall, in the same room and 12 feet from the floor drain.
was doing laundry and the washer drain pipe overflowed as well as back wash water flowed up from the floor floor drain and left a large pool of water on the floor.
vacummed water up from floor and used a 25 ft drill auger on the washer drain pipe and got it clear....or more clear as before, i could only run water into that drain pipe a few seconds and it would overflow, but now i can run it slowly almost continuously, but i now see the water rising in the floor drain when i do that.
So i tried to get the auger into the floor drain but cannot see or find the main shoot in the floor that leads the water out to the street.
when i put the auger in it hits at 3 ft deep like it hitting the floor. I sat there for 10 minutes with the auger spinning and it never found a hole to allow me to release more of the auger.
Is there a trap door or something that i cannot see?
is it your standard p trap design ?
Should i try to open that cleanout near the wall even though that is above where the problem seems to be?
