I have a house w/ a four plex in the back rented out. The city of pasadena inspects all residential rental property, every four years. So this time around, they decided three of th the 5 heaters(gas w a tank) were new enough to require permits. To further complicate things, the house from the 1910's, has its htr in the basement.
I already ran 2 pipers per htr from theptr valve And from the pan underneath out of the buildings and 6" above grade. Except for the one in the basement. Its already below grade. So the part where it must run down hill, and cant go up at all, is difficult. So i put in a watts 210 valve on it. But it also req's a pr valve some where on the hot side. I first tried to put on ton the hose bib near the the basement. Anyways this is what im trying to research. Thanks.
