underpressure
Hello all!
My problem is relatively simple: we have a well outside, that the previous homeowner installed solely for watering his garden. We've been trying to do the same, but it hasn't exactly worked out. This well has four hose hookups, and we've got a sprinkler attached to one of those. When we turn the well on using the 220v breaker in the garage, the sprinkler comes on, but water begins spraying out of the other 3 outlets. If we turn any of these 3 off using the valves on the end of them, the pump sputters for ~10 seconds, and then blows the breaker. We don't believe that the well has a pressure tank, (unless it is underground?) but in the pit, there is a pipe with something that looks about like this attached to it. If we try to adjust that, using instructions like you would find on this page, nothing seems to happen. Is this because there isn't a pressure tank? What is the best way for us to water the garden without spraying water all over the yard? If pictures could be helpful, let me know and I can go take some ASAP.
Thanks in advance!
Thanks in advance!
