three_jeeps
I am facing a complete shower tearout to the studs and redo with ceramic tile, and getting a BM together. A neighbor recently went through this and the contractor used Wedi board. The neighbor has had issues with water leaks in the floor as well the side walls, specifically lower half where the wall meets the pan. This is a 30 yo bath so it has seen its day. The neighbor, wanted something totally waterproof and decided to use the Wedi system (boards, floor pan, etc.) for every thing.
I looked into using wedi and it seems to offer lots of advantages over Durock, and the various other 'backer board' products out there, but is more expensive and using the urathane joint sealer can be a little trickey . I have no problem with that if it really does waterproof the interior. It seems that this is the ideal product for this application but from what I've seen, doesn't get speced a lot.
Thoughts on using Wedi vs others? is it really better as far as being water proof?
thanks
thanks
