Bar_Nett87
Hello Everyone,
I'm new to the forum but I have a feeling I'll be more regular as I continue to have various problems with the house I recently purchased. Here is my latest issue, I was hoping to get some advice?
I have a well and I lose water pressure about 20 minutes into a shower. It's fine up until then however once it drops out the first time it starts to cycle between running ok and no pressure. The longer I continue to shower the more frequently it cuts out. The pressure in the entire house is affected, i.e. when it cuts out in the shower it cuts out in all of the faucets & toilets too, then cycles accordingly. It happens with both hot and cold water.
I swapped the pressure switch, it is a 60/40 switch but this made no change.
I checked the air pressure in the tank, it was about 35 PSI and showed no signs of water at the air valve.
If I turn my shower and all the faucets off, the well achieves ~55-60psi (on the gauge coming off the tank). If I turn the shower on, the pressure then appears to cycle between 40-60 as expected however after some time of running, it begins to cycle low (0-30), which correlates with the pressure drops in the house.
If anyone could give some advice it would be greatly appreciated!
Thanks for reading!
*Chris
Thanks for reading!
*Chris
