Water stops when turned offI was able to view the video but only after downloading to my computer. When you say "handle" do you mean a water control valve or the shower diverter tub spout? With the water completely turned off, does the leak from behind the tile at the interface to the tub stop? If it does, it looks like the tub diverter spout is not properly installed on the copper pipe coming out of the wall and needs to be replaced/repaired. Fix it soon because there is no telling where that water is getting into behind the tile!!
I’m sorry done. Only way to view video is by downloading to computer. It was uploaded through iPhone.Post a pic, the forum doesn’t support video for iphone
The tub spout is not sealing to the copper pipe coming out of the wall. I've done it myself in the past and know that the copper stub needs to be squeaky clean and with no gouges or burrs in the copper. I used a strip of ultra fine emery cloth to clean up the pipe before installing the new one.Water stops when turned off
I agree about the caulk.The tub spout needs to be replaced. I've done it in the past myself and
On a fun note, if the caulk had been up to snuff you would have never known about the leak because all the water would have gone into the wall!
