Hello,
I have an issue with water backing up in the laundry room. My laundry room drain pipe (1.5") is connected to a T connector with the drain pipe (1.5") from bath tub. This t connector is then connector to a P-Trap which then connects to the main drain pipe.
Whenever there is more water going thru bath tub drain pipe, instead of going into p-trap and main line, some water backs up in the laundry drain pipe and sometimes comes out in to the washer drain pan. Drain pan is about 2 feet above the t-connector which connects bath tub drain & laundry drain pipes.
I moved the washer and opened the drain strainer of the drain pan to see what is happening. Whenever there is a sudden gush of water going thru bath tub drain, water comes up the laundry drain pipe with bubbles. This happens for few seconds and then it seems that all water goes thru the main drain pipe as it shud have been.
I am confused as to why water would go against gravity for few seconds before going in the expected route. First I thought there might be some clog in the drain pipe. So tried with baking soda + vinegar + boiling water. However I have never seen water being stopped or going very slowly. Its just that it backs up for few seconds in the laundry drain pipe before going out.
Also the washer drain pipe is connected to the same pipe as washer drain pan before that pipe connects to the bath tub drain with t connector.
I am not sure what the problem is. Would appreciate if someone could help with what could be the potential problem and how to resolve it.
FYI, am a first time home buyer and bought this townhouse 3 months back.
