user 32510
- Joined
- Sep 24, 2023
- Messages
- 7
- Reaction score
- 1
Hello, I’ve searched a few forums but still haven’t found a good answer as to why my two toilets sharing one vent like to bubble and gurgle and splash when the other toilet is flushed. The two drain into one 3inch pipe as pictured. The center pipe is the vent pipe which connects to the original 4” cast iron pipe going through the roof.
There are no other venting problems anywhere in the house (anymore).
The main 4” cast iron pipe is leaking, so I would like to reconfigure the vent pipe while replacing the 20 feet of cast iron. ( I can use 3” S&D pipe all the way across the run right? Or should I use 4” due to the length before it hits the the cast iron underground pipe?)
So why does this cause gurgling and how might I be able to reconfigure it so it stops splashing water up the opposite toilet with every flush?
Thanks!
Thanks!
