Custom500
The toilet in my home always worked fine, and still does, except all of a sudden and for no apparent reason when we flush it you have to hold the handle down or the flapper sucks shut immediately. We have lived here 32 years, and of course I've had to replace the flapper a few times, and mostly they worked OK, except maybe you had to jiggle the handle once in a while, but probably 10 years ago I put an aftermarket American Standard style job in, (with the float and the cup that empties to time the closing), and that thing worked perfectly, every time without exception. Suddenly the valve drops as soon as you release the handle- half a flush, no good.
So- I removed the old American Standard style unit and to my surprise the float had not leaked and had no water inside, but I replaced the whole thing with a new fluidmaster flapper (it came with the overflow pipe and everything). Same thing, slammed shut as soon as I released the handle. Playing with the float on the chain made it all worse. So- Went on line and bought an the exact same American Standard style aftermarket unit (that turned out to be a Kissler 68-7089) and put that in, and now IT won't work right either. What the...
All 3 of these valves stand straight up when they opened, but then drop almost immediately. I even tried to add some weight to the cup on the A.S. one to help hold it open longer while the water drained out of the little hole, but it didn't make any difference. All ideas appreciated.
