Hi all,
So I’m wanting to replace the face of a tub overflow and drain, just to clean up the look of the tub, and will also be replacing the shower and tub spout (easy part)
My issue is I’m not familiar with this overflow drain type, it’s a rotating overflow (not a lever) to popup the drain stopper.
I want to just replace the face of this and install a new drain (with toe tap popup).
I can’t find anything that would fit this square rod coming from the overflow that would fit as the overflow cover.
Does anyone have any thoughts or advise on this? I don’t know the brand of the overflow and drain, but the tub spout and shower are a Kohler brand(Model: forte) from what I can see.
I attached photos of the overflow and after I took the cover off. I just want to replace the cover to give it a clean look.
Thanks
Marko
Thanks
Marko
