Hello. I own a tri level home with basement (four separate levels) that was built in 1973. This morning I woke up and noticed sewage all over the inside of my downstairs shower, which is on a concrete slab. The force of this back up was somewhat powerful as the sewage splashed on the shower curtain and seemed to "ruffle" it up a bit. There was mostly fecal matter and toilet paper in the shower basin.
I do not believe that this is a main sewer blockage because I washed a load of clothes in the basement, beneath the floor with the downstairs shower, and I did not have any backing up in the basement wash tubs. My washing machine drains into the basement wash tubs.
I worked on the clog in the downstairs bathroom all day without much success, of course my snaking tools were not working out so well because they are so old. I definitely need to upgrade my snaking tools, but to be honest, I never had to snake a clog like this mess.
It seems as if the shower clog will drain SLOWLY over the course of many hours. The toilet, located directly beside the shower, is also clogged and will not drain. If I plunge the toilet vigiriously, it will sometimes come up through the drain in the shower. If I plunge the shower, it will sometimes cause the toilet to bubble. Also, using the sink in the same bathroom will result in water coming up into the shower basin.
There is another bathroom located directly above this bathroom on the top floor. I just did a quick test where i flushed the upstairs toilet, and the sewage came up through the drain in the downstairs shower. I assume the upstairs sink and shower will do the same.
This is the first time I have ever had a back up like this in this bathroom. I never use the shower down there, though. However, occasionally I will run water through the shower just to keep the drain P-trap filled and it is always fine. I do use the toilet down there occasionally, and I never have an issue as well. I also used the toilet down there a few days ago and didn't experience any troubles.
I scooped out most of the facal matter and toilet paper from the downstairs shower basin. It seems as if the flow of toilet paper is done, however, if I flush the toilet and try to plunge it, or use the sink, dark brown water (fecal!) is still backing up into the shower basin.
Any suggestions? I poured about 3/4 gallon of Draino down the shower drain without any impact.
