LearningToBeHandy
I've had to replace a few copper pipe to brass hose bibs lately and have a hard time getting them undone.
I'm using basic propane and torch setup and my technique has been to cut the brass hose bib off or partially off using an angle grinder with diamond wheel. Otherwise it seems I can't get the brass hot enough and or water evacuated enough to get the solder undone. I also have had to stick a little piece of sponge into the copper pipe to get the little trickle to stop from the pipe. (I know lack of patience).
In any case I'm wondering if I will be better off with map fuel and torch. I've been kind of eyeing the push button start torch heads too.
Any thoughts?
Any thoughts?
