I am installing a toilet in the garage on a slab. The toilet is going to be the standard 15" from the finished side wall. The side of the toilet faces the outside wall. The main sewer line is 3 feet away and 2.5 feet down on the outside of that wall. Using a standard closet bend, I would run into the footing. Can I have vertical pipe below the toilet, then go horizontal to the main with 1/4 inch per foot slope? I plan on running the vent behind the toilet in a 2x4 wall. Does the vent need to be connected to the horizontal section or can it be in the vertical section, if vertical drop is allowed? I am in Oregon.
