jpokerwinski
Does the 3" toilet drain need to be vented ? i remember reading somewhere that you can not use a AAV for toilets correct ?
but you can NOT use a AVV correct ?Yes it has to be vented
well i am not sure i need it for the toilet but i have a shower and vanity that i am moving that i may need to use a AVV for those becuase it may be too far from the existing vent. Stupid question.. can you have a AVV and a normal vent on the same drain line. the normal vent is close to the toilet, the AVV will be farther away.Technically, it would work, but it may not meet local codes.
Oatey, makes a large size range of AAVs, from 6 to 500-DFU (Drain Fixture Units), with a residential toilet having a rating of 5-DFU. So, the parts are available, and the IPC, and UPC both allow it.
