I pulled up a lead pan shower today and was removing the flange bolts and they snapped. (I only let the pb blaster work for 10 minutes).
3 of the 4 bolts snapped. I can probably still ezout them. Are there any better options?
I am replacing the shower floor. Im using a schluter Kerdi tray and they want a solid plywood floor. Does that mean the lower flange needs to get removed anyway?
If I remove the lower flange, and replace the subfloor, how will I attach a new flange to the drain? I have no access from below and I have cast iron pipes.
