Nickernator
Hello,
I am looking for ideas/suggestions on a simple and low cost way to add a timer to a ball valve, located on a heated (200F) waterline.
I have a 3/4" ball valve that controls the boiler feed into a large stainless tank. The ball valve is typically opened for small increments (3min- 10min) in order to increase the temperature of the stainless tank. The issue I have is that I open the valve, set a timer on my phone, walk away and forget. If I leave the valve open it adds way too much heat to the system taking hours to cool, and risking serious damage. You'd think I could see that issue and stand there counting down the seconds until shutdown, but that just isn't my nature come to find out, and no matter how hard I try I still manage to overheat the system regularly.
I found some cheap solutions like this one...
https://www.amazon.com/Automatic-Mo...cphy=9033106&hvtargid=pla-1183326411015&psc=1....but this product doesn't exactly instill confidence. At$35 I wonder how long it will last, and my luck with WIFI cameras tells me that this isn't going to work for my application.. but I like the idea.
I would like to install a common solenoid valve (9-24v) and control it with a simple timer of sorts. The idea being that the valve/setup will be reliable, and in the future I can add this valve to the rest of the automated system via a standard connection.
I'm not too familiar with plumbing components but this is the idea of valve I'm looking at...
https://www.grainger.com/product/2H...LVHT2erTylGmIqVQ2jcaAib3EALw_wcB&gclsrc=aw.ds
I would like to use this type of valve (im open to suggestions), with a wall mountable timer capable of easily setting increment in minuets, that will countdown the set time and shut down the valve reliably. Im also not too keen on electrical, so Im open to ideas on timers etc.
Thank you guys for your help!
