I recently had a new indirect hot water heater installed (had an oil fueled water heater prior) which uses the oil fueled boiler that i use to heat my house. The heating system worked fine before the installation. After installation the main zone of heat would not come on. Plumber came back and fixed some wiring. Now all of the radiators and base board in the house are hot. He claims its due to something called 'floating heat' caused by the boiler turning on to heat the hot water but since the circulating pumps are old, the boiler is sending hot water through to the heating system. Something seems off about this, why wouldn't he have discussed or solved for this during the install? Any advice is appreciated.
