pvc reamer
Are you looking to chamfer/deburr, or remove pipe from a fitting hub. We use the Reed ones at work and they're awesome for getting pipe out of a fitting hub.
I’m too cheap to buy a good one.
I’d like to have the one that cuts off a 3” over pipe closet flange. I’m too cheap 🤓
yeah., I use it personally., try it... makes the pipe slide all the way into the joint withOUT pushing the glue., creates a nice tapered edge.
I use a chop saw when I do new work. I bevel the edge with the side of the cut off blade.
Small repairs I just put it together.
