Context: We've had a gravity-fed spring for 20 years (no pumps or electricity..all gravity). The spring and the concrete holding tank are about 1,000 feet away up the mountain from our house. I'm not sure about how much elevation gain but it's worked well for us for 20 years so I guess elevation is proper.
Problem: Recently, we noticed that the water pressure is fine for about 30 seconds and then slows to a trickle. Or, if the water pressure is fine in a sink, it drops to a trickle when flushing toilet.
If you wait a while, the pressure returns, only to diminish when you turn it on for about 30 seconds.
Response: I pulled the lid off the concrete tank. It's full of water. It's overflowing over the overflow pipe. We looked to the (not sure what you call it) the output pipe at the bottom of the tank. It appeared to be unclogged.
Possible problem? We're thinking maybe the overflow line is clogged and that blowing it out would help. Does this sound correct?
