So I was replacing the kitchen faucet on Saturday, after everything is done, I found there is very slow leak under the P trap. I investigated a bit further, it's the coupling from the P trap to a pipe that connects to the dishwasher's outgoing hose. There is some buildup at the end of the pipe (the end that connects to the coupling) and the scary thing is that if I put a little force on the pipe, it actually moves. I am afraid it's going to break soon.
Please see the attached pictures, on the P trap it's a male end with the outer diameter of 2 in, the copper pipe's outer diameter is 3/4 in.
Can I just buy a new female adapter (with its inner diameter of 2 in) something like Everbilt 2 in. Copper DWV Cup x FIP Female Adapter Fitting C903HD2 - The Home Depot, then use a flexible coupling to connect the new coupling to the copper pipe?
I would like to use a 2 in to 3/4 in reducer with a female end, but no luck. The aforementioned adapter is the only one I can find. I also have problem finding a fitting flexible reducing coupling to connect the new adapter to the copper pipe.
Any thoughts and ideas will be appreciated.
