I have two toilets, back to back. The toilets are both "Skyline Champion 4" with the huge flush valve, the one they show flushing golf balls.
I have to say, they do as advertised but maybe too well...
Flushing the upstream toilet will siphon water from the bowl of the downstream unit. After about two or three flushes, the downstream bowl is almost emptied out, enough so that sewer odors are detectable. In reverse, the downstream will also siphon from the other, but not nearly as much. The bathroom drains are the last on the line with a direct, straight shot to the septic tank, line is clear, vent is clear.
The drains come down from the toilets then into 90* ells and into a 4-way Tee. The 4-way also has a 2" side inlet for shower and bath drains (also back to back) and the vent stack. The sink drains run in the wall to the vent stack above the floor line.
Any ideas on how I can remedy this situation? The only thing I can think of would be to install at least one P-trap, (maybe two) between the Ell(s) and the 4-way Tee.
The system is glued ABS pipe and space it tight, but I may be able to rube goldberg the P-traps in using no-hub fittings.
Thanks!
David
Thanks!
David
