scofopolis
Prior tenants mentioned that there was sometimes an intense sewage smell in the basement. We moved in a few days ago and noticed it for about 15 minutes - then it went away.
Basement has a sump pump (pics here: ) - wondering if it is coming from there?
In hot water tank room there is another pump system (for waste I am assuming). I noticed around some of the pipes (where they screw into one another), there is dried brown residu. Could this be the source potentially? Some gas / sewage leaking out when the pump is activated?
I'm not very adept at plumbing, so apologies if this question sounds a bit silly. Thanks in advance for the help!
