ahr6912
Only one problem both hot and cold hub in that laundry room in concrete then goes the perspective areas. So, you need to pipe everything from the attic down to the laundry room, master bath, kitchen, and guest bath. Then the recirculation line from eaches further runs in that area back to the tankless and still need the check valves, balancing valve, and aquastat pump. Unless you live in California and afraid of Legionalles in the water lines.
